| View previous topic :: View next topic |
| Author |
Message |
Joined: 12 Nov 2007 Posts: 1232 Location: Hays, Kansas
Posted: Fri Nov 06, 2009 12:51 pm Post subject: Pro-Filer 375cc Sniper X |
375cc Sniper Super X ( conventional head with all stock placement features. Nothing is moved. No special parts needed)
2.350 1.850 or 1/880, 119.5cc chambers can be angle milled to 106cc
All flow figures are done on a 4.625 bore with 2.350 intake and 1.850 exhaust.
FLOW PRO Compare Data Report
________________________________________________________________________________
No. Test Name Date Max CFM Avg CFM Operator
1 Profiler365I4 FINAL 11/5/2009 470.3 361.7 DARIN
2 Profiler365I3 FINAL 11/5/2009 479.8 371.8 DARIN
3 Profiler365E001 11/6/2009 333.0 259.9 DARIN
ACFM
Lift No. 1 No. 2 No. 3
0.2000 156.0 156.0 128.3
0.3000 234.0 234.0 170.6
0.4000 306.0 306.0 205.2
0.5000 360.0 368.4 236.7
0.6000 406.8 414.0 298.3
0.7000 427.2 451.2 313.6
0.8000 444.0 468.0 321.3
0.9000 459.0 477.0 327.4
1.0000 471.6 481.2 332.2
Average: 362.7 372.9 259.3 |
| Back to top |
airflowdevelop
Posted: Fri Nov 06, 2009 4:45 pm Post subject: |
Bring the rain!
I'm doing my excited dance! |
| Back to top |
J_6961
Posted: Fri Nov 06, 2009 6:18 pm Post subject: |
You'd almost think Darin knows what he's doing.  |
| Back to top |
shawn
Posted: Fri Nov 06, 2009 7:38 pm Post subject: |
Any more details on these? Is this an "as cast" head? Cnc'd? Any cross section numbers? These look like they'll fit right into a project I'm getting ready to start.
Thanks,
shawn |
| Back to top |
jracing
Posted: Fri Nov 06, 2009 7:59 pm Post subject: |
| that sounds like a good head you have there can you put up some pics?? |
| Back to top |
jracing
Posted: Fri Nov 06, 2009 8:00 pm Post subject: |
| also how much$$$$? |
| Back to top |
Posted: Fri Nov 06, 2009 8:12 pm Post subject: |
All Darin told me way they are being put on the fast track to get ready for release. They will be CNC heads. Maybe Darin will chime in on particulars.. _________________
cspeier@att.net
www.SpeierRacingHeads.com |
| Back to top |
Posted: Sat Nov 07, 2009 12:23 am Post subject: |
| Chad Speier wrote: | | All Darin told me way they are being put on the fast track to get ready for release. They will be CNC heads. Maybe Darin will chime in on particulars.. |
There was another part too
Wait till they get a load of this!
they, hmmm, they? Ok I know  _________________ cranecams.com
tricktrucks.com |
| Back to top |
Darin Morgan
Posted: Sun Nov 08, 2009 8:35 am Post subject: |
I was trying to come up with a little better conventional head than what we currently have. It ended up being better than I ever hoped for. I used one of my Texas Pro Stock heads that I did for Joe Pigford as sort of a basis. He sent them in to be freshened up just in time for me to use them as a template. Our 365cc and 385cc heads where exceptional four years ago but time stands still for no one especially me. Last week we decided that our heads needed updated so I put everything on the back burner and went full bore for six days to come up with a better mouse trap. I went through three heads before I came up with two ports that fit the bill perfectly. I trashed a lot of casting before I settled on these two ports and this one exhaust port. I have a 365cc port done (it flows about the same) as well but we will come out with this one first as it fits the most engine combination's. This is a STOCK replacement meaning that all off the shelf conventional components will work. As a matter of fact most will be abale to take there heads off and put these on with minimal effort. Everything is the same as our 385cc heads except the port and chamber designs.
(1) Stock port height of .485-.490 off deck.
(2) Stock valve train either stud mounted or Jesel /T&D bolt on.
(3) All conventional manifolds will bolt right up.
(4) 2.350 1.850 or 1.880 valve in standard conventional location
(5) No need for custom pistons.
(6) Your push rods may not need replaced. |
| Back to top |
hsutton
Posted: Sun Nov 08, 2009 11:15 pm Post subject: |
| trmnatr wrote: | | Chad Speier wrote: | | All Darin told me way they are being put on the fast track to get ready for release. They will be CNC heads. Maybe Darin will chime in on particulars.. |
they, hmmm, they? Ok I know  | Butch, what are you trying to say, just spit it out? |
| Back to top |
J_6961
Posted: Mon Nov 09, 2009 10:13 am Post subject: |
| Darin Morgan wrote: |
so I put everything on the back burner and went full bore for six days to come up with a better mouse trap. | And on the seventh day, he would rest .....  |
| Back to top |
Ricky McConathy
Posted: Wed Nov 11, 2009 8:05 pm Post subject: |
| Quote: | | I was trying to come up with a little better conventional head than what we currently have. It ended up being better than I ever hoped for. I used one of my Texas Pro Stock heads that I did for Joe Pigford as sort of a basis. He sent them in to be freshened up just in time for me to use them as a template. |
I hope you didn't copy them too closely to pig's stuff, or there will become a bunch of super comp dragsters flipping over backwards
ricky _________________ Slick Rick Racing Heads
Naiser Racing Components |
| Back to top |
Darin Morgan
Posted: Fri Dec 04, 2009 10:43 am Post subject: |
| Ricky McConathy wrote: | | Quote: | | I was trying to come up with a little better conventional head than what we currently have. It ended up being better than I ever hoped for. I used one of my Texas Pro Stock heads that I did for Joe Pigford as sort of a basis. He sent them in to be freshened up just in time for me to use them as a template. |
ricky |
Your kidding of course. Pigs heads flow anouther 35+cfm at .800 lift and have optimized valve locations so expect these ehads will be 80hp behing Pigs heads but $8k less expensive! LOL  |
| Back to top |
dragracer300
Posted: Sun Dec 06, 2009 5:34 pm Post subject: |
| Are These Oval Or Square Port? I Know Darin Really Like The Oval Ports For Good Reason. |
| Back to top |
Darin Morgan
Posted: Mon Dec 07, 2009 1:01 pm Post subject: |
| dragracer300 wrote: | | Are These Oval Or Square Port? I Know Darin Really Like The Oval Ports For Good Reason. |
Oval ports only function "perfectly" in a conventional head when the port volume is under 320cc and the valve OD is 2.300 or smaller. Once you get into the 350-360cc or higher range you must go to a more square type port in order to get the air speed correct. learned this over a decade of messing with them. In my personal opinion, others use the "oval" as a gimmick when the square would actually function better. I have no high power conventional head that are oval port including Joe Pigfords TPSA heads that flow 500cfm+. |
| Back to top |
