| View previous topic :: View next topic |
| Author |
Message |
Dr J's Performance
Posted: Tue Oct 27, 2009 9:26 pm Post subject: ProFiler 210 As Cast Dyno Test |
We were building a customers engine...and I convinced the customer to try a set of 210 Pro-Filers. This is the first set I've had the chance to do some dyno testing with. The plan is to make a 550-560 hp pump gas 400.
engine specs block #817 400
4.165 bore X 3.75
RaceTec flat top Pistons 1.5mm 1.5mm(napier 2nd) 3mm ring package
Rpm Crank and H beam rods
Custom Isky HYD roller
248 @.50 intake and EXH 108 LSA 104 ICL
.373 lobe 1.6 intake rockers 1.5 exh.
Fully Ported Professional Products hurricane Single Plane
& 950 HP holley carb
I thought this type of street strip combo would really show what these heads are capable of.
After Some clean up work on the heads (Blow blend and gasket match) I think the engine will make 570hp plus!
flow numbers on a Profiler 210 AS CAST (no cnc porting) with a valve job and gasket match
tested a 28" with a 4.155 bore fixture
Intake 2.08 valve
.100 74 cfm
.200 135 cfm
.300 197 cfm
.400 243 cfm
.500 282 cfm
.600 290 cfm
.700 295 cfm
.800 299 cfm
Exhaust 1.60 valve test with a 1-3/4 pipe 3" long
.100 59 cfm
.200 112 cfm
.300 162 cfm
.400 189 cfm
.500 205 cfm
.600 212 cfm
.700 221 cfm
.800 228 cfm
We did some back to back intake manifold testing on this engine. We test our fully ported Professional Products Hurricane vs. a as cast.
HP and TQ increase over as cast intake
________TQ_____HP
3000rpm + 6.3 + 3.7
3500rpm + 2.6 + 1.7
4000rpm +1.5 +1.5
4500rpm +7.3 +6.3
5000rpm +11.8 +10.4
5500rpm +14.4 +16
6000rpm +14.3 +17.2
6300rpm +20 +25
Peak TQ 5000rpm 545 ft lbs
Peak Hp 6300rpm 581 hp
TQ per cube 1.335 ft lbs
HP per Cube 1.424 hp
As Cast Intake
Ported Intake
 _________________ Bryce Mulvey
Dr J's Performance
"The Home of Innovative Air Flow technology"
(714) 943-3404
www.j-performance.com
Last edited by Dr J's Performance on Tue Oct 27, 2009 10:17 pm; edited 1 time in total |
| Back to top |
Joined: 12 Nov 2007 Posts: 1204 Location: Hays, Kansas
Posted: Tue Oct 27, 2009 9:41 pm Post subject: |
There is a player in the SBC cylinder head department. Pro-Filer!
Nice looking build!
PS. Always wanted to ask, do you build dominators? _________________
"Everything begins with Trust"
cspeier@att.net
www.SpeierRacingHeads.com |
| Back to top |
lilgoat
Posted: Wed Oct 28, 2009 7:29 am Post subject: heads for my setup |
wow so with my build would the RHS 235 be my best bet sbc 400 509 block filled race tec piston 5cc dome 13.01 com. scat 4340 3.75 crank scat 4340 procomp i beam rod 6.125 soild roller not sure yet on cam, jesel rr 1.55,going malibu 12 bolt with 4.56 gears 28.5 tires on alky powerglid want to run in the low 6's do you think you can get me their with out nos will run some nos later on help  _________________ TRUST IN JESUS!!!!!!!!!!! |
| Back to top |
Posted: Wed Oct 28, 2009 8:41 am Post subject: |
Looks good Bryce _________________ cranecams.com
tricktrucks.com |
| Back to top |
hb_350
Posted: Wed Oct 28, 2009 11:34 am Post subject: |
| Nice results Bryce, thanks for sharing. |
| Back to top |
Kemper
Posted: Thu Oct 29, 2009 10:25 am Post subject: |
Very nice results! I would love to be at the pump with that engine in my car after a few blasts down the strip, watching everyone ride bye...  |
| Back to top |
Posted: Fri Oct 30, 2009 12:49 am Post subject: |
Do you have the correction factors used on that pull and what were the weather conditions?
What is the Inertia factor and how does it effect the dyno data?
Is the vacuum data accurate? It seem really low for that size carb.
Have you looked into why the AFR readings were off from one side to the other? _________________ Bill Simpkins
smallblock 406
1/8 6.42@106.5
1/4 10.15@130.5
Fourtenposi@yahoo.com |
| Back to top |
